[SOLVED] Sidebar Not Disabling
Description of the issue: Sidebar stays enabled despite it being turned off, just would just to know if there’s a fix for it.
  1. I enabled it by accident upon pressing something on the keyboard, haven’t been able to get rid of it since.
Expected result: I disable the sidebar in settings or using right click and the sidebar should go away.
Brave Version( check About Brave): Version 1.52.126 Chromium: 114.0.5735.133 (Official Build) (64-bit)
Can you please try pressing Ctrl + B and see if the Sidebar closes?
Thank you
Results when pressing Ctrl+B and pressing it again
@DaltonG Just to confirm, does it still appear if you completely exit Brave and then open again?
fixed it, thank you, no reason to close my browser so I rarely do so.
