Hi, i´m not able to donate to Bat verified creators on youtube. The “bar” to donate BAT´S doesn´t appear on youtube channels, it appears on twitch and on sites though.
I already changed profiles and the issue still persists. What solved is to create a new profile, but that doesn´t seem too atractive being that my bat´s are on the wallet of my main profile.
I´m using windows 10 home, version 1909 [64 bits], and brave [Version 1.18.70 Chromium: 87.0.4280.101 (Official Build) (64-bit].
Link to image of the issues:
Ps: The problem existis even on other profiles of the browser were created months ago but i never used , the same issue is “solved” when i created a new profile just to test if it solved the issue at hand.
[Solved] I disabled all my extensions, it worked
