Is it possible that without verifying with Uphold wallet that it will not show as verified? My channels do not show on my end as being verified via Brave Rewards. I tried deleting the file while all instances of Brave are closed, thanks for detailed help everyone.
Yes. Shown as verified on my end.
Connecting Uphold account is required in order to receive the contribution. Not for verification process.
Hi,
I also get this issue. When viewing on the android app I am verified but not in the windows browser. I looked for the “publishers_list” file in the appdata/local folder and found no instance of the file in the brave folder.
I look forward to the fix
Got the same problem on Android app.
And can’t reinstall the app
I will loose my bat…
Is there any fix ?
I have the same problem, my YT-channel is not verified…
https://www.youtube.com/channel/UCcLDCP_jxFJB3TTfW8z9UNg?view_as=subscriber
I have deleted the publisher_list but it doesn’t work.
Is this Bug still being implemented? I have three sites that I have verified. They show differently on multiple devices. But on this browser none of them show verified. Laptop shows one verified. Phone shows one verified but different one.
Is the fix still being worked on?
Larry
Fix is absolutely on the way – sorry for the inconvenience!
Added my account on added 2019-05-08 to be verified and well still nothing just like all these people.
I deleted the “publisher_list” and still showing as not verified
Also ran as admin over and over and still nothing.
Fix date coming sooner i hope!
Real fix coming
Sorry that we couldn’t resolve your issue!
I have reinstalled my Brave Browser on Android and now I lost my 10 BATs with this move…
I don’t know, how I can restore it…
Hi I registered my brave website https://seanaye.ca over 48 hours ago and in my brave rewards it says it is registered. I have deleted the publishers file (MacOS) and re-opened brave but I am still “not verified”. If i open the newly downloaded publishers file in a txt editor I can even see my website name in there. How do I fix this and does anyone view https://seanaye.ca as registered?
Hello, just wondered if it was possible to confirm that https://daccaa.com has been added successfully?
Hi Danny, I can confirm the link is verified. Could you please try https://seanaye.ca
Hey! Thanks for that. I checked your link and all seems verified from my end.
With the new update, I can check my status to verify it again. But the brave browser doesn’t save the status and it shows me after I close brave or the website that I am not verified again…
A fix is on the way
Thanks Asad! This looks to be fixed. There is now a “Check Again” Link. I clicked check again and viola. Verified! Thank you very much.
I like the Brave browser! Great job!
Larry
Ok. So, it turns out its kind of fixed. It shows verified but when you close and open again, it says Unverified again. But, you can click Try Again and it verifies. So, I guess it’s progress. I’ll take progress any day! Just wanted to update.
Thanks again.
Larry
Can anyone help me at this topic?
Make sure you’re on the latest version of Brave
Then you can open up the Rewards Panel (click the BAT icon in the address bar) and click the “Check Again” text that comes up in that window.
