So.... are you ever going to fix sepll chekc?
EDIT: Why can’t I delete this?
But also: if it’s OS-dependent, why suddenly after years of misspelling “necessary” did the spell check start showing total gibberish as the “correct” spelling shortly after switching to Brave? I screw up that word all the time and never had an issue correcting it. Oddly enough, just now it showed the correct spelling as the only suggested replacement. It’s been like a month since that’s happened. Weird. Anyway… can someone just delete this seeing I don’t seem be allowed?
See my edit… also: can you not delete threads here? there’s no point for this to stay up.
it changed after switching to Brave, see edit to orig comment (also: it started working properly again literally as I was editing)
