MY Gmail inbox appears in really tiny print other programs an feature are normal it is only the Gmail in box. Is there a option that changed that I( can change back
You have zoomed out the site
Click on that minus and click on reset and everything will be fine, or just press ctrl + 0 from the keyboard
Thanks much appreciated
