Slow website translation problem
Hi, I wanted to ask if there is a solution to loading the translation from a site faster…sometimes it takes up to 10 seconds, thanks.
Yes, the translation is slow, slower than google translate which is only less than 2 seconds. And the problem with the detected language feature.
Brave Translate really needs to be fixed.
Translate does not translate automatically at all. Why not just set it to use Google translate.
