no change of settings or extension except deactivation of material acceleration
can the browser be started from the command line with debug or log flags?
chromium starts up normally
in short words when you need to look for some flags in brave look for it in chrome (unless it custom option added by brave) and most of the time same will apply
thx @justsomeone1,
I’ve tested it and it takes a while to start up on the following lines
[196169:196169:1017/142253.465010:WARNING:sandbox_linux.cc(393)] InitializeSandbox() called with multiple threads in process gpu-process
[196170:196170:1017/142308.437265:INFO:child_thread_impl.cc(926)] ChildThreadImpl::EnsureConnected()
could you add this flag after the previous one --disable-gpu this will disable hardware acceleration
maybe it gpu driver issue
do you have dual gpu card ? if yes could you start brave with each one and see if the issue related to one of them (of course without using the disbale gpu flag)
my graphics card is a gt710 and
I’ve installed the aur nvidia-470xx-dkms package,
my motherboard is an MSI MPG B550 Gaming Plus and
my processor is an AMD Ryzen 5 5600.
[225487:225487:1019/164659.807443:ERROR:object_proxy.cc(577)] Failed to call method: org.kde.KWallet.isEnabled: object_path= /modules/kwalletd6: org.freedesktop.DBus.Error.ServiceUnknown: The name org.kde.kwalletd6 was not provided by any .service files
[225487:225487:1019/164659.807467:ERROR:kwallet_dbus.cc(112)] Error contacting kwalletd6 (isEnabled)
[225487:225487:1019/164659.807601:ERROR:object_proxy.cc(577)] Failed to call method: org.kde.KLauncher.start_service_by_desktop_name: object_path= /KLauncher: org.freedesktop.DBus.Error.ServiceUnknown: The name org.kde.klauncher was not provided by any .service files
[225487:225487:1019/164659.807612:ERROR:kwallet_dbus.cc(81)] Error contacting klauncher to start kwalletd6
[225487:225487:1019/164659.807731:ERROR:object_proxy.cc(577)] Failed to call method: org.kde.KWallet.close: object_path= /modules/kwalletd6: org.freedesktop.DBus.Error.ServiceUnknown: The name org.kde.kwalletd6 was not provided by any .service files
[225487:225487:1019/164659.807741:ERROR:kwallet_dbus.cc(503)] Error contacting kwalletd6 (close)
[225487:225487:1019/164659.808185:ERROR:object_proxy.cc(577)] Failed to call method: org.kde.KWallet.isEnabled: object_path= /modules/kwalletd5: org.freedesktop.DBus.Error.ServiceUnknown: The name org.kde.kwalletd5 was not provided by any .service files
[225487:225487:1019/164659.808195:ERROR:kwallet_dbus.cc(112)] Error contacting kwalletd5 (isEnabled)
[225487:225487:1019/164659.808307:ERROR:object_proxy.cc(577)] Failed to call method: org.kde.KLauncher.start_service_by_desktop_name: object_path= /KLauncher: org.freedesktop.DBus.Error.ServiceUnknown: The name org.kde.klauncher was not provided by any .service files
[225487:225487:1019/164659.808315:ERROR:kwallet_dbus.cc(81)] Error contacting klauncher to start kwalletd5
[225487:225487:1019/164659.808428:ERROR:object_proxy.cc(577)] Failed to call method: org.kde.KWallet.close: object_path= /modules/kwalletd5: org.freedesktop.DBus.Error.ServiceUnknown: The name org.kde.kwalletd5 was not provided by any .service files
[225487:225487:1019/164659.808438:ERROR:kwallet_dbus.cc(503)] Error contacting kwalletd5 (close)
[225487:225487:1019/164659.808784:ERROR:object_proxy.cc(577)] Failed to call method: org.kde.KWallet.isEnabled: object_path= /modules/kwalletd: org.freedesktop.DBus.Error.ServiceUnknown: The name org.kde.kwalletd was not provided by any .service files
[225487:225487:1019/164659.808794:ERROR:kwallet_dbus.cc(112)] Error contacting kwalletd (isEnabled)
[225487:225487:1019/164659.808900:ERROR:object_proxy.cc(577)] Failed to call method: org.kde.KLauncher.start_service_by_desktop_name: object_path= /KLauncher: org.freedesktop.DBus.Error.ServiceUnknown: The name org.kde.klauncher was not provided by any .service files
[225487:225487:1019/164659.808909:ERROR:kwallet_dbus.cc(81)] Error contacting klauncher to start kwalletd
[225487:225487:1019/164659.809012:ERROR:object_proxy.cc(577)] Failed to call method: org.kde.KWallet.close: object_path= /modules/kwalletd: org.freedesktop.DBus.Error.ServiceUnknown: The name org.kde.kwalletd was not provided by any .service files
[225487:225487:1019/164659.809028:ERROR:kwallet_dbus.cc(503)] Error contacting kwalletd (close)
[225487:225487:1019/164659.809374:ERROR:policy_logger.cc(154)] :components/enterprise/browser/controller/chrome_browser_cloud_management_controller.cc(163) Cloud management
controller initialization aborted as CBCM is not enabled.
[225487:225801:1019/164659.867810:ERROR:object_proxy.cc(577)] Failed to call method: org.freedesktop.DBus.Properties.Get: object_path= /org/freedesktop/UPower: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.UPower was not provided by any .service files
[225487:225801:1019/164659.867923:ERROR:object_proxy.cc(577)] Failed to call method: org.freedesktop.UPower.GetDisplayDevice: object_path= /org/freedesktop/UPower: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.UPower was not provided by any .service files
[225487:225801:1019/164659.868013:ERROR:object_proxy.cc(577)] Failed to call method: org.freedesktop.UPower.EnumerateDevices: object_path= /org/freedesktop/UPower: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.UPower was not provided by any .service files
[225487:225487:1019/164659.884793:ERROR:network_service_instance_impl.cc(663)] Network service crashed, restarting service.
