Site fails to load with CryptographicException
Attempting to navigate to an internal site, the page fails to load throwing an exception.
The exception is the same with shields up or down.
The page loads without problems with Google Chrome
  1. Navigate to a qulkview page … this, I assume, redirects to a company SSO page
The result is an exception
Server Error in ‘/qliksso’ Application.
Error occurred during a cryptographic operation.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.Security.Cryptography.CryptographicException: Error occurred during a cryptographic operation.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[CryptographicException: Error occurred during a cryptographic operation.]
System.Web.Security.Cryptography.HomogenizingCryptoServiceWrapper.HomogenizeErrors(Func`2 func, Byte input) +172
System.IdentityModel.Tokens.SessionSecurityTokenHandler.ApplyTransforms(Byte cookie, Boolean outbound) +167
System.IdentityModel.Tokens.SessionSecurityTokenHandler.ReadToken(XmlReader reader, SecurityTokenResolver tokenResolver) +784
System.IdentityModel.Tokens.SessionSecurityTokenHandler.ReadToken(Byte token, SecurityTokenResolver tokenResolver) +88
System.IdentityModel.Services.SessionAuthenticationModule.ReadSessionTokenFromCookie(Byte sessionCookie) +512
System.IdentityModel.Services.SessionAuthenticationModule.TryReadSessionTokenFromCookie(SessionSecurityToken& sessionToken) +258
System.IdentityModel.Services.SessionAuthenticationModule.OnAuthenticateRequest(Object sender, EventArgs eventArgs) +143
System.Web.SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +139
System.Web.HttpApplication.ExecuteStepImpl(IExecutionStep step) +195
System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +88
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.7.3429.0
Page is properly displayed
Version 0.68.131 Chromium: 76.0.3809.100 (Official Build) (64-bit)
I tested with Version 0.68.132 Chromium: 76.0.3809.132 (Official Build) (64-bit) with the same result
Source Error:
Stack Trace:
[CryptographicException: Error occurred during a cryptographic operation.] System.Web.Security.Cryptography.HomogenizingCryptoServiceWrapper.HomogenizeErrors(Func2 func, Byte input) +172
System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +88`
The issue still exists in Version 0.68.138 Chromium: 77.0.3865.75 (Official Build) (64-bit).
Any thoughts or updates or is this not a priority at all?
