Button to enable “Single Domain Mode.” In this mode, browser loads only items from websites that DNS resolve to the same domain [EDIT and sub-domains] as the address in the URL bar. It ignores IP addresses entirely.
Brave loads only HTML elements served from my-banking-site.bank domain, and ignores elements and trackers loaded from other domains like facebook.net, adsrvr.org
HTML code that specifies IP addresses is ignored or GET is bypassed.
DOESN’T THIS DUPLICATE ADBLOCKING?
From a user perspective, yes. From a functional standpoint, there is no need to disable javascript, or use adblock lists, because the browser refuses to see anything other than the single domain listed in the URL bar.
CAN’T THIS BE BYPASSED BY CREATING DNS ENTRIES IN THE SINGLE DOMAIN FOR ADVERTISER WEBSITES?
Yes. For example, facebook-1x1-image.my-banking-site.bank could be created in the my-banking-site.bank DNS domain, but how many companies would go to that trouble of updating and maintaining DNS entries in their own domain for external domains
In order to connect with and use Chase Bank, the following domain/host names must not be blocked. Also, some are sources for cookies, and some are sources for JavaScript:
Thanks for catching my mistake. I assumed subdomains in my head, but did not state that. I’ve edited my comment above. I appreciate your example of Chase Bank, but I don’t think all the non chase-dot-com items are strictly required for banking. If it doesn’t work for Chase Bank, then you turn the mode off. For my bank, allowing on my bank and bank’s subdomains would break a live chat widget, and a banking-optimized customer tracker. I’m fine if both of those are broken.
The example isn’t limited to just banking, but was meant to be illustrative and describe a future desired state. That’s why the request for a button where the feature could be turned on or off and not a required state that breaks everything.
Websites are more fussy about “YOUR ID / PASS” particulars; more websites require persistance - stability about your presentation.
Brave Browser Site-Specific Shields is occasionally not reliable, for some websites. A Brave Browser user might decide to lower Shields, and the website sees a change, whereupon the website challenge changes, and the website forces some kind of reload … and just like that, you discover that the Site-Specific Shields choice you just made, does not stick or “it worked yesterday!”
Better to approach some websites, or at least test, with settings that are established in advance and they endure:
The Chase banking example is a great example. If Chase wants to use some other domain’s scriots then CHASE can route a copy through THEIR server AND take responsibility for its actions
Someone a couple decades ago said “Your idea will break the way the web works”. Yep, and in a good way. Nobody’s domain should be conveying some other entities risk onto the end user.
