You will LOVE this amazing side/vertical tabs extension for Chrome/Brave. It works perfectly and has fantastic options!
This feature is being implemented (work-in-progress) and it already works really great in the latest official build (Brave version 1.47.186 Chromium version 109.0.5414.119) - itβs already more reliable than the mentioned extension.
You need to enable it via the flags (brave://flags/#brave-vertical-tabs) since it is still in Beta and then right-click on a tab to finally enable it in the UI after restarting the browser.
Have fun!
Edit: Updated the mentioned versions and added links.
