Side by Side configuration error
Description of the issue: When opening a Brave profile pinned to my taskbar, it throws error code: The application has failed to start because its side-by-side configuration is incorrect. Please see the application event log or use the command-line sxstrace.exe tool for more detail.
  1. Open profile from taskbar
Expected result: Browser opens as normal
Brave Version: v1.47.186
Additional Information: tracetest log attached. The reason it is called E is the fix to an old issue where the browser would flash open for ~0.1 seconds then quit. https://pastebin.com/HD4D8SRz
Windows 10
I7 9700k
32gb 3200mhz ddr4
RTX 2070 Super
Hello @Earthvirgo10, thank you for reaching us out. This seems to be a Chromium known issue please take a look on the following video:
Hope that can fix your issue. Regards.
