Shields Built-in AdGuard Turkish Filter list does not work properly
If I use the built-in Brave Shields AdGuard Turkish filter list on some sites e.g. Dizipal some Ad Banners show up. If i add AdGuard Turkish list link manually from their site (https://adguard.com/kb/general/ad-filtering/adguard-filters/) this issue does not happen.
The site when I add manually:
https://dizipal911.com/bolum/reacher-1x1-c01
yes
No
Does the ad appear when using a Private window as well? (yes/no)
yes
What OS are you using when you see the ad?
Windows 11
Version 1.76.82
@m3r7y2nd
Your issue will be of interest for Brave team member @fanboynz who handles Web Compatibility matters.
He is a busy fellow and will likely read this; and then proceed without leaving any “FanboyNZ was here” message.
So, I figured - given that you are new here - I’d leave a note, so you know, “somebody noticed.”
