If you open brave://settings/ straight after install (without changing the default small window size), navigation sidebar (with redirects to all different settings sections) does not show due to being hidden on small width.
- Open
brave://settings/ - Resize browser window width down to default size or lower
- Observe only “Get Started” section being visible
- Rage ensues
Main navigational element of a page should not be hidden with no trace.
Main page of settings should not be only a useless “getting started” section.
Version 1.32.106 Chromium: 96.0.4664.45 (Official Build) (64-bit)
Just installed the browser and went into settings only to be greeted with condescending “edit your avatar!” and not actual privacy/security settings.
