Settings on mobile don't work
Hey,
I just downloaded Brave on my mobile (huawei p20 pro) and after that is well on my laptop.
When i wanted to sinc them i did get the qr code on my laptop screen but not on my mobile.
when i open the brave ap on my mobile, click on the logo in the right upper corner and then click on settings it goes straigt to rewards. in the reward menu i don’t see a option to go to other settings or to sinc it.
How do i sinc my foon with my laptop then?
tanks in advance!
@mau35,
Are you trying to Sync you Rewards data, or use Brave Sync to sync your bookmarks across devices?
The same thing happened to me… I had to manually type in the all the 24 key words…
When i did the device was added…
But in my phone i had .10 BAT and in the laptop it said 0.00 BAT…
Dont know if the accumulated BAT shows in both devices… Or you can earn double rewards from 2 devices…
And me as well. :frowning:
