In Settings - Passwords - I have a block of settings for Extensions which covers up a number of my saved password settings.
Every time I open Settings and go to Saved Passwords it is there
Should not be covering up the password saved entries. If there is a way to remove the whole Extension block in the picture that would help as I do not use.
Always there
Win 7 32 bit up to date
Brave is up to date
Version 0.64.77 Chromium: 74.0.3729.169 (Official Build) (32-bit)
I had two versions of Brave showing in Control Panel - Programs and Features from where I updated from Muon. I have deleted both (eventually as I had to go into registry to delete all entries) apart from the Brave entry in AppData Roaming, and reinstalled again. This issue was present before and still is.
