The bar when you click the 3 dots to open up options like desktop site or settings becomes pure white on dark mode(I assume the text is white on a white background which should be black). Also happens when I go on different websites where you try to make it dark but it doesn’t work, resulting in all white.
(Doesn’t happen very often, but usually happens when taking these steps)
- Three dots - > settings - > appearance - > themes
- Switch to dark mode but DO NOT PRESS X instead press the back button until you exit settings
- Close the browser
- Open it
- Click on the 3 vertical dots
Attached gif
Pretty often, but not always
Operating System and Brave Version(See theAbout Bravepage in the main menu):
Brave 1.8.112, Chromium 81.0.4044.138
Android 9, ANE-LX1 build/HUAWEIANE-L21
This works like a fix:
- Go to settings - >… - > themes again
- Switch to light mode
- Press on X, DO NOT HIT THE BACK BUTTON
- Go to themes again
- Press the X button to exit settings completely
