I used your instructions in Brave browser to set Brave Search as default but when I click to make it default, that option is grayed out. Can you help?
@Celmo,
Thank you for reaching out.
That is strange – is that contained in your list of default search engines or in the “other” search engines list?
Hello Celmo, I had the same probelm. This is how I got around it.
Open the Brave browser and navigate to search.brave.com
Open menu in upper right corner of search page
At tne top left open -’ See All Setting’
You will see this -Scroll to bottom of page
Select -Make Brave Search Default
When page opens scroll to bottom and select- Don’t see Brave Search in the list?
Select -ADD
Navigating the pages in this order is the only way 'default ’ became active.
