Set custom search engine in mobile
Description of the issue: How do I set a custom search engine in the mobile browser? I want to use Swiss Cows but there is no option to do so.
  1. Go to settings:search engines; no option to add a custom one
Expected result: There would be a custom option like on the desktop browser
Brave Version( check About Brave): 1.57.60
Mobile Device details Galaxy Note10
Hey. We can’t add the engine this way yet.
So to add any engine, just enter the Search engine URL.
For example I used Ecosia
Entered ‘https://www.ecosia.org/’ then made a search using Ecosia engine → now go to settings → Search engines → you’ll see the Search engine under recently visited
I’ve tried that, but it’s not showing up. The same two websites (pine street not even being a search engine) are all that keep showing up under “recently visited”, I can’t get it to refresh or update to a latest used search engine. I’ve attached a screenshot.
Alex Stephen
thewheelm4n@protonmail.com
