Hello, there you go, I have a restrictive problem with brave when I have to register on certain sites, sometimes the sites ask to write an address, you need to start writing the (postal) address and when we start writing the information, there is a drop-down menu that will propose addresses, or even to define our gender from a selection menu of choices, but sometimes with Brave it doesn’t work and I have to switch to Firefox to be able to continue my registration, I see this as a kind of automatic entry, but I don’t know if I name it correctly, my apologies in advance if bad pronunciation on my part.
I imagine that there is some adjustment to be made somewhere in brave, but I don’t know what needs to be touched, to be able to correct this inconvenience. Can you help me to correct this inconvenience please? Why does only Brave have this constraint, while there is no problem with any other browser on this subject?
Please use the template below. I’m going to be guessing if I don’t know a bit more, like what version of Brave, what OS, or in this case, what site? I’m not exhibiting any issues with auto-filling menus on the websites I visit (for example when entering state I can usually tab “F” and “FL” shows up for Florida) so in order to properly troubleshoot, please include as much in the template below:
NOTE: Any “one-liner” or topics requesting support or reporting bugs that do not make an effort to include as much of this information as possible will not be responded to. Repeatedly posting as such is grounds for banning._ Please try to adhere to this template when reporting bugs. If you think you don’t need to fill out every section in the template fill out as much of it as you can and please be as descriptive as possible when posting.
