Scrolling and Animations Sluggish
  • Scrolling the page using Brave is sluggish in comparison to Chrome and Edge.
  • It appears that there are random dropped frames. Interestingly, it sometimes scrolls smoothly, but rarely.
  • This started around 1-2 months ago.
  • I don’t notice any abnormal CPU / RAM spikes.
  • Further testing shows that animations are also sluggish in brave
  1. Load any website
  2. Scroll using precision touchpad
  3. Observe lag / dropped frames
Should be smooth like Chrome and Edge
Brave Version:
V1.26.74 (June 30, 2021)
I am using Windows 10 on a Surface Book 1 - I have just reset this device to a fresh install of windows and Brave, but still get this issue.
Just wanted to share my solution:
  • I realised that I couldn’t detach the surface book display whilst brave was running, so it was using the dedicated graphics card.
  • I set the graphics options in windows to force brave to use the intel cpu graphics.
  • Note that I don’t have to do this for chrome or edge.
@Grid,
Great detective work – GPU issues have been kind of a pain for us in general. We have documented some of the GPU issues/workarounds we have here:
