Saved passwords are not updated
I have noticed that auto login doesn’t seem to work recently.
Today, I just changed a saved password and I got prompted to update password and I clicked Update but when I went into the Settings > Autofill, and I viewed the password, it was not updated.
Brave Version 1.46.153
Hello there @emkf thanks for reporting this and accept my apologies for the issue. Could you please try creating a new Brave profile and try updating your passwords to see if the issue persist there?
You can open a new profile by going to Main menuCreate a new profile
Let me know if that works.
Hi @Kevin_cc.
Thanks for the prompt response and sorry for my late response.
I don’t think I have a profile setup so I am going to try out your suggestion and see how it goes.
@emkf hi again, please let me know if that works or if the issue persist in order to further investigate.
I just updated a password after creating a profile and it works.
@emkf hi again, if it works on the new profile, please try disabling your extensions, if you have any, to see if that solves the issue
Some of my saved passwords disappeared.
I don’t know if this is related to my OP. It looks like it isn’t since many of the passwords got carried over to the new profile but I don’t know for sure because of the timing of when this happened.
@emkf does the passwords you are missing appear on your original profile or they are lost from both your profiles?
