I am using Brave on three devices since 2019: Main PC (Windows 10 Pro), Laptop (Windows 10 Home) and Phone (Android 10). I get ads and payouts on all devices. On none of those devices the “Rewards summary” screen works nor does the monthly statement screen. Never worked in all the time I used Brave.
Rewards summary always says “No activity yet”, even though I do get payouts. The Monthly Statement screen lists 0.000 BAT (respectively -0.000 BAT for the donations) for every month.
All devices are connected to the same Uphold account.
What am I doing wrong?
Is your browser wallet currently verified? (yes/no): yes
What date did you verify your wallet? 2019
Have you been able to successfully receive payments in the past? yes
Are you in a supported region (see here for list of supported regions)? yes
Does your device pass the SafteyNet check (Android only)? yes
