Rewards is missing, help?
Briefly describe your issue:
Missing reward; January. Help.
Android, Brave 1.33.106
No
First time
Are you using a VPN? (yes/no)
No
No
Yes
Not linked to uphold
Hello?? Anybody?? Are there any support in here??
Hello… Support, exist?
There is no support. And this about the missing payment is a huge problem which many people are facing right now.
I dont know anything more than that. Sorry but I just wanted to write to tell you to sit tight in the boat. Seems this has been an ongoing issue since 2019 if you read forum history…
Welp…
Thank you dear sir :slight_smile:
Hi :slight_smile: If you still haven’t received your BAT, you might want to DM a moderator. Include a link to your post and the information requested in the link below when you DM.
If you have received your BAT, just reply to your post and then select “Solution” and it will close the topic. Good luck!
