Rewards drop down displays small white box
Ads have stopped and the rewards page displays only a small white box
I do not know how to reproduce this issue for another user. Ads and rewards page stopped working properly approx. 14 hrs ago.
v0.68.131
have not touched any settings or options
e: have just received an ad and can access rewards through the "customize and control’ menu. got credited. drop down still has a white square.
Hi @ryabj
Welcome to community! Can you share a screenshot of the white square?
Hey @steeven,
I have the exact same issue. Here is the screen :
My Brave Version : Version 0.68.131 Chromium: 76.0.3809.100
Thanks !
Hi @horatiounaee, is that MacOS or Windows?
@steeven Windows 10, Version 1903 :smile:
edit : Just updated to Brave Version 0.68.132 Chromium: 76.0.3809.132, issue is still here
@steeven exactly the same as @horatiounaee
it is just the square though. rewards and reward page are still working.
To any constellation I’m having the same issue. Small white box when the Brave rewards triangle is clicked…
Brave version - Version 0.68.132 Chromium: 76.0.3809.132 (Official Build) (64-bit)
Windows version - Windows 10 Pro / version 1903 fully updated.
I have reset browser to defaults with no joy.
Note:
if you right click in the small white box you get options please see imagebrave
I can confirm this as well. Same small white box.
On my second browser at home, it works fine, but the Rewards Pop Ups are glitched. A faded white box with barely readable text and no close button.
Hi @ryabj @horatiounaee @imkzru,
Thanks for your patience here. This is a known issue and can be tracked here - https://github.com/brave/brave-browser/issues/5336.
It is currently in Beta and should be in Release in 0.69.
