Hi, I don’t understand why in March my actual earning is 1.861 BAT and my total March rewards arriving is 0.795 BAT. Could someone understand the reason? Thank you.
Thanks for writing in.
When a new month begins, the display value of the current earnings will reset, and you will now see a countdown that tells you when your BAT earnings over the previous month will be arriving (for example, “+0.02 BAT arriving in 5 days”).
The estimated earnings you’re seeing up until this point have included these BAT that were not yet reconciled — so when your final payout balance for the month is calculated, its a mismatch between what was estimated and what is actually earned.
It basically means that you earned from it, but the ads aren’t reconciled by the time the payment period starts. So for example, if you earn .05 BAT at the end of the payment period, that BAT may take a couple days to be reconciled (maybe “processed” is an easier to understand term) — which means it doesn’t actually count towards what you earned this month and you’ll instead earn it next month.
