[ resolved ] Kee not work in Brave
Hello,
Kee not work in Brave see this link : https://forum.kee.pm/t/kee-3-7-7-beta-not-work-in-brave/3526
Thank’s for assitance
sorry i am using a french / english online translator
hey,
Looking at the screenshot, at Brave we block third-party 127.0.0.1 requests, which is probably causing the issue.
Translated:
En regardant la capture d’écran, chez Brave, nous bloquons les requêtes tierces 127.0.0.1, ce qui est probablement la racine du problème.
Thank you, but how to unlock 127.0.0.1 so that Kee works, only on Brave it doesn’t work and it’s really annoying
Please give me a solution to unlock 127.0.0.1 on Brave
Thank you
Disable ‘ads and trackers’ in shields. The only solution.
There is no other solution than this?
There must be an internal setting to unlock the 127.0.0.1 !!!
Since it works on Google Chrome, vivaldi an edge browser based on Chrome
A few extensions did break recently, we are investigating the source of the issue.
Thanks!
This issue is a showstopper to me, and I love Brave!
Fixes incoming, https://github.com/brave/brave-browser/issues/14473
An updated Brave release in the coming days hopefully.
@Markco @jalonavens New release of Brave 1.21.74 will fix this, just update, restart. Apologies for the issues.
Using :
Version 1.23.21 Chromium: 89.0.4389.72 (Build officiel) nightly (64 bits)
no fix for me. Keepass is always off
Work fine to add in: brave://adblock
||localhost^$important,third-party
||127. ^$important,third-party
||[::1]^$important,third-party
||192.168.
@@127.0.0.1
Using :
Version 1.23.27 Chromium: 89.0.4389.86 (Build officiel) nightly (64 bits)
Deleting the addition of parameters in brave: // adblock work fine, kee extension is on
