Currently Brave has no in built “Speed Dial” feature. It’s heck of an important & needy feature people like us. While in Desktop there has 3rd party speed dials in the Chrome store, but there has privacy issues as well. So, I don’t want to use any 3rd party extension & invade my privacy.
On Smartphone (Android), it’s heck of a pain in the ass that Brave mobile browser doesn’t even support chromium extension. And there has no buit in Speed Dial feature. So, unlile desktop on Android there has no way.
So, I’m requesting to the Developers community that please consider to add Speed Dial feature both on Desktop & Mobile client of Brave Browser.
Thanks.
I have used speed dial on different browsers and it is something I used several times a day (hour). I very much like Brave but not having a usable speed dial detracts from all the positive aspects of Brave.
Brave has url shortcut, not speed dial.
Can’t able to manually add shortcut.
After browsing a site, shortcut got automatically added. I don’t want it that every site I visit & brave placed a shortcut.
I want to manually add my shortcuts more than 20 or 30 sites on my homepage.
Which Brave doesn’t support.
To put that into perspective, thats my daily useage sites which I customized to place the url shortcut on my homepage.
But Brave doesn’t support adding many speed dials, not even adding sites manually on homepage, not any single customization.
On Desktop, there has a little bit of customization hidden beneath but on the Mobile there has no single way.
Brave mobile version has no customization on homepage.
Meh
The built in favorites is very limited and does not compare at all. Being limited to a small portion on the new tab page which is constantly replaced by every new site you visit.
The best replacement is “Speed Dial 2 New tab 3.2.6”. Problem is this extension is unable to download website previews while a VPN is active. Also doesn’t allow you to add icons manually unless you pay for a subscription.
The best “Speed Dial” I’ve found so far is the built in speed dial that is included in Vivaldi (another chromium based browser).
Problem is Vivaldi is slow as snot in comparison to Brave, but does offer improved privacy over Chrome, Edge, Opera and Firefox.
Brave as far as I can tell is very fast with great privacy. It just doesn’t include as many features as the other browsers.
Like picture in picture. The PIP included in Vivaldi is amazing as it appears as a button only when mouse is hovering over the video. Then the PIP can be resized as large as you want.
Would be amazing if Brave Devs could adopt Vivaldi’s style of Speed Dial which integrates directly into favorites and can be edited extensively if desired. (Editing in the browser GUI itself is a bit limited)
Also adopt Vivaldi’s Picture in Picture.
If Brave devs can do this Brave would be the fastest, safest, browser to date.
Opera has the most efficient speed dial set-up. You can have an infinite number of speed dials and create folders for similar sites to group together. I have to believe the developers at Brave would have the same abilities creatively. That would make Brave the best browser of them all.
