Hi @steeven,
I’ve uninstalled Brave on my windows 7 computer 32 bit .OS.
When I try and reinstall the latest version a dialogue box keeps popping up saying:
“No update is available”.
- Please advise what the fix is?
Thanks in advance.
Hi @steeven,
Thanks in advance.
@Mattches can you please help with the above problem?
Thankyou.
This is because Windows 7 support has been dropped — note that this is the case across most Chromium based browsers:
@Mattches is there an older Brave version that I can download and use on Windows 7?
If yes? Please reply with the download link. Thanks.
@Toa2024,
I believe v1.46.134 was the last version supported, which you can find here:
According to feedback from people, it’s 1.47.186 that was last update available for Windows 7 and 8.1.
Ah you’re right — good catch. Thanks @Saoiray!
Out of the many download links listed for v1.47.186, which is the correct one for my system?
Thanks in advance.
@Toa2024,
I believe you can use the base BraveBrowserSetup.exe:
@Toa2024,
That’s my mistake, I believe you should actually be using the BraveBrowserSetup32.exe installer. My apologies.
