Region not supported for INDIA
When is going to fix the problem of region not supported problem for india with gemeni account
It’s not a problem, is a feature.
India will be added when they find a solution to cope with all the KYC and legal stuff.
India is at the moment a priority, so keep an eye in the following updates:
e class='quote' data-post="1" data-topic="417552">
For new information, check bottom comment. Otherwise can review some of the below to see overall status since July 26, 2022. Brave’s List of Supported Countries OLD UPDATES BELOW: Can’t add more since April 4, 2023. Update: April 4, 2023 Only because it’s been a little while since I gave an update, thought I’d just do a small post. At this point they still have nothing solid to say about adding countries again, the new partner(s) they are hoping to add, or even of an ETA for the sunsetting of v…
France & India was the top two priority to re-enable verification. Verification with uphold is re-enabled for France this week & now India is next. You can expect it within 1 or 2 months.
