Briefly describe your issue:
After resetting my uphold password, browser disconnected from uphold, when reconecting received the “not suported region message”. The thing is, that I received the montly payout hours ago, and I can do connect and reconect with the Brave Creators, the only problem seems to be linking again the browser with Rewards. What Operating System and Brave version are you using (Menu --> About Brave)?
W10 Is your browser wallet currently verified? (yes/no)
yes What date did you verify your wallet?
2020 Have you been able to successfully receive payments in the past?
yes Are you using a VPN? (yes/no)
no Are you eligible for Brave Rewards (see here for list of supported regions)?
Argentina Are you on the list of supported regions when verifying Brave Rewards with a custodial partner (see here for list of supported regions)?
Have you manually turned off Auto-contribute on all of your devices linked to a custodial partner?
yes
@ret012 That’s because Brave is not supporting Argentina for custodial partners for Brave Rewards at this time. It has not been supported for months now. Sure, you may have been getting payments because you had been linked, but once disconnected you’re not able to connect again until Brave adds the region again.
Hello Brave Community,
In consultation with the team at Uphold, verifying Brave Rewards with an Uphold account will now only be available in the following countries of registration, effective immediately (starting July 12, 2022):
Australia
Austria
Belgium
Canada
Denmark
Finland
Hong Kong
Ireland
Italy
Netherlands
New Zealand
Norway
Portugal
Singapore
Spain
Sweden
United Kingdom
United States
For countries no longer on this list, Uphold and Brave will continually work together to evaluate whe…
e class='quote' data-post="1" data-topic="393482">
Hello Community,
In consultation with the team at Gemini, verifying Brave Rewards with a Gemini account is restricted only to the following supported countries of registration, effective immediately (meaning that only users in the following regions will be able to verify with Gemini at this time):
Australia
Austria
Belgium
Canada
Denmark
Finland
Hong Kong
Ireland
Italy
Netherlands
New Zealand
Norway
Portugal
Singapore
Spain
Sweden
United Kingdom
United States
For other areas not currently on…
e class='quote' data-post="1" data-topic="417552">
For new information, check bottom comment. Otherwise can review some of the below to see overall status since July 26, 2022.
Brave’s List of Supported CountriesOLD UPDATES BELOW: Can’t add more since April 4, 2023.
Update: April 4, 2023
Only because it’s been a little while since I gave an update, thought I’d just do a small post. At this point they still have nothing solid to say about adding countries again, the new partner(s) they are hoping to add, or even of an ETA for the sunsetting of v…
