Unfortunately, your Brave Rewards cannot be verified because your region is not supported for Brave Rewards verification at this time.gemini and uphold not verifying.any another ideas.
hey, it is because when Uphold disconnected, it was showing and will continue to show Rewards wallet balance till you are able to successfully connect to Uphold/Gemini.
The error is shown because your region is not supported for rewards verification at this time. Brave is working on getting support back for Brazil and India soon. These 2 regions are their priorities right now.
More details can be found here →
e class='quote' data-post="1" data-topic="417552">For new information, check bottom comment. Otherwise can review some of the below to see overall status since July 26, 2022. Brave’s List of Supported Countries OLD UPDATES BELOW: Can’t add more since April 4, 2023. Update: April 4, 2023 Only because it’s been a little while since I gave an update, thought I’d just do a small post. At this point they still have nothing solid to say about adding countries again, the new partner(s) they are hoping to add, or even of an ETA for the sunsetting of v…
Also next time, before creating a new topic, please search the forum. This topic has been discussed too many times and there’s a lot of indo available as well.
