- Estimate bat decreased
- Ads rewards rate decreased
- No ads today
- No response from admins
Hi @Ramees1996 - we’ll need for info in order to help.
What OS and Brave version are you on?
What country are you in?
Are you using a VPN?
Have you installed any new extensions?
Thanks in advance!
Hi @steeven I am also facing the same issue and my android OS version is 10 and brave version is 1.8.112 and I am from India, and I did not install any new extension. The problem is today my bat reduced by 0.5 and I am not getting ads and also I got only 0.1 bat for around 10 ads
Same issues over here BAT reducing drastically
Hi @Ramees1996 - the next payout is scheduled for Friday. If you do not receive the expected amount please let me know. Thank you.
@steeven ok.now the ad rewards rate is back to normal.and i am ok with missing(just .4 bats)rewards .thanks for the response
awesome, glad to hear it @Ramees1996!
