Update your browser to the latest version.
Keep the browser open for long periods to allow proper reconciliation.
Wait until the end of July and check. The rolled over rewards should be included in the next month’s payment.
I have the same issue, I should have gotten a bit more than 23 BAT while I got 20.5 . I am using the latest version and the missing amount is not included in my current earnings for last month, so I guess the issues to pay the correct amount are still lingering
So they believe it to be fixed and things should have arrived by now. I guess I’d suggest you make sure the browser is updated, perhaps restart the device, and then check if it can be claimed. If not, then you’ll need to do the good ole support ticket
