When web trying to use ReCaptcha, the ReCaptcha block/square/section/box only flashes and juist gone. Some website doesn’t even appear and just say that ReCaptcha verification failed but no ReCaptcha box appear
This is some fixes i try but still not worked
- disable shield off for global and current site
- cleared cache and for all the time
- reinstall
if I’m not mistaken, this started to happen after I updated my brave several days/ a week ago
[Version 1.32.106 Chromium: 96.0.4664.45 (Official Build) (64-bit) ]
Can someone help me? I’ve been switching to edge for some web that needs ReCaptcha and it’s kinda annoying
Please fix this and next update please
Thank You, have a great day
@SilvaneUX,
Thank you for reaching out.
Can you please provide an example website in which you observe this behavior so I can take a closer look?
https://misterhorse.com/ : when trying to register there should be a recaptha box but not showing and tell me that recaptha failed
some online image upscaling site similiar to waifu2x : wont show too
reddit : when trying to message mod or posting on sub : captha box showed up but always cnt connect to recaptha service
that’s what i found from yesterday-today. there are plenty more but i forget what site and which section the problem is
@Mattches
@SilvaneUX,
I just registered for misterhourse.com and was able to do so successfully, but I was not prompted with any captchas. Tried wifu2x and was able to successfully click on I am not a robot and complete the captcha:
Some extensions may be interfering with the behavior, do you have any installed at this time? Additionally, are you using a VPN connection when you encounter these errors?
@Matches Thanks for your solution, I just found out that my urban VPN extension is enabled (even tho I’m not using it).
so I disabled it and it’s working now.
this is a working solution for me.
Thank you very much. Have a great day.
@SilvaneUX,
You’re very welcome, glad were able to get that resolved.
