There is no reading mode available in browser for android and windows. reading mode is useful when reading long articles with unnecessary clutter.
I have read about Speed Reader Mode but I cant find it anywhere .
Because it’s not available yet. It’s a “research”.
For now:
On Android, you can use Simplified Views. Go to Brave’s Settings > Accessibility.
On desktop, IIRC you can use “Distill page” from Main Menu.
Thanks for the info. One more issue is I can’t download any files on android. It says “Sd card not found”. I use one plus 6t and it doesn’t have Sd card. Please help.
Please see Can't Download, SD Card not Found
Hi, any news about a button for “reader/reading mode” as Opera or Firefox?
Thank you!
You can activate the SpeedReader feature using a flag if you like.
I highly recommend it
navigate to brave://flags
search for speedreader
set the option to enabled
restart Brave
a SpeedReader setting will be available in the Appearance of Brave Settings.
here is the flags page
and here is the settings page
cheers!
daniel
Generally, I agree with your suggestions.
But.
Going to brave://flags/ I’ve had varied experience editing the options. One bad experience: disabling New Tab Page Branded Wallpapers and New Tab Page Demo Branded Wallpapers resulted in the entire Appearance section of Settings disappearing.
Specific to Brave’s Speedreader option in Windows installations, I suggest leaving the Enable Reader Mode flag set to Default. The result (for me): when I load a page with content that Speedreader can distill, I see the Brave Speedreader icon toward the right end of the omnibox. I can toggle it on or off.
A Speedreader alternative: toward the bottom of Settings | Appearance, there’s a switch for Speedreader. Default is off. If you switch this to on, Speedreader will automatically distill pages it can process. That’s not what I want, but the option is available.
More info here: What is Speedreader?
