You will not be able to connect to Uphold because your country is no longer supported.
But you should be able to received the future rewards in your browser. If you do not, then please open a support ticket.
No. Brave is trying to find a solution. But it may take several months until most countries are supported.
There is a post with some updates on this subject.
For new information, check bottom comment. Otherwise can review some of the below to see overall status since July 26, 2022.
Brave’s List of Supported Countries
OLD UPDATES BELOW: Can’t add more since April 4, 2023.
Update: April 4, 2023
Only because it’s been a little while since I gave an update, thought I’d just do a small post. At this point they still have nothing solid to say about adding countries again, the new partner(s) they are hoping to add, or even of an ETA for the sunsetting of v…
Oh, no!!! It’s not fair!!!
