When downloading attachments from Protonmail only the first one works. Select the second attachment to download and it spins its wheels but does not download it. Sign out of Protonmail, sign back in, then download the next attachment.
**Steps to Reproduce (add as many as necessary):
As above: download an attachment in a message, then try the next attachment.
Only first file is actually downloaded.
Just keep loading down files as selected.
Every time
Win10, Brave 1.24.85
Works fine using Protonmail via Microsoft Edge. Problem is occurring on 1 desktop and 3 laptops, all using Brave in Win10.
Sounds like an authentication problem with ProtonMail’s server. Do you have third-party cookies enabled? If not, try that.
Looks like when I click to download a second attachment Brave thinks Protonmail is opening a pop-up. It doesn’t, but allowing protonmail.com to do that in settings gets around the problem. Not sure whether it’s a Brave or a Protonmail problem, but I’ve found a circumvention for now.
Still puzzled though - why doesn’t it happen on the first one???
Hey PeterQ,
If you search for Automatic Downloads, you should see two lists: Allow and Block. Can you check to see if it works after putting protonmail under Allow, if it’s not already on that list.
