Progressive Web Applications (PWA) in Brave
Some sites, if not many on Brave doesn’t allow to be added as Web Apps, so I’ve thought why not copy Edge’s approach and make it available for every website there is.
This is already the case in Brave. Even if the site does not display the “Install…” icon in the address bar you can still create a web app for the site by opening the Main menu, then Save and Share --> Install page as app...:
Oh, I actually haven’t been aware of this since I started using the browser, thanks for informing me. Also, is it supported for every page online?
Yes, this should work for all sites.
Hello, is this feature also available on iOS?
Brave doesn’t let me install any PWA’s (I have to install them with Safari).
@gmacar unfortunately no, this feature is not available in Brave on iOS due to the limitations they put on devs using WebKit.
How can we disable the nag to install a PWA?
It’s annoying. It’s something that I (and probably hundreds of thousands) will never, ever use. It’s peer pressure.
It’s evil, and must have an option to disable, so that those of us who despise these can still use a browser without hating it.
