Hello, I have been having problems using YouTube, for example, I can no longer pause a video or fast forward with the space keys, or forward or backward arrows. Any suggestions?
Hello @Leopardo, thank you for bringing this to our attention. Have you updated to the latest Brave version? Please try disabling/enabling the AutoPay option under brave://settings/content/autoplay to see if it makes any difference.
On the other hand if you are using extensions might be one of them is interfering with the correct functionality of your keyboard try removing some of them and let us know if the issue persists. Regards.
hello! hey thank you very much if it helped me, in the end it was an extension that prevented me from using the keyboard
Now I can continue using my favorite app ![]()
You’re very welcome
Glad to hear it worked for you
Best Regards.
