Problems with youtube playback for playlists
When playing a playlist on youtube in the background, it randomly happens that after a video ended a random video gets played (which is not in the playlist) instead of the playlist continuing. This does not seem to happen when:
  1. You have the youtube tab open in the foreground
  2. You play the first video(s) of the playlist (It usually takes about 2 videos to happen)
The behavior of the playlists seems to be very irregular, sometimes the playback works for several videos in a row and sometimes not even for one. It appears to get better when you are not logged in but the issue still occurs. It seems to happen more frequently after longer videos. Having shuffle enabled seems to make it happen considerably more frequently.
Exact URL of the website in question: https://www.youtube.com
Did the issue present with default Shields settings? (yes/no) yes
Does the site function as expected when Shields are turned off? yes
Is there a specific Shields configuration that causes the site to break? If so, tell us that configuration. (yes/no): no
Does the site work as expected when using Chrome? yes (probably)
Brave version (check About Brave): Brave 1.92.134
It seems this problem can be fixed by either updating the adblock lists or enabling experimental ad blockers. I did both and it seems to be working fine now, however since this problem was really inconsistent it is possible that I just happened to really lucky during my tests.
I tested it again, updating adblock lists still does not solve the issue
