Problems with Updating Chrome and Brave Error Code 3: 0X80040154 – system level
  1. Description of the issue:
    1. I go to Settings/About Brave to attempt to update desktop software on a new Win 11 PC
    2. A Windows UAC windows pops up and I click Yes to allow App to make changes.
    3. Then the update fails. The same exact thing happens for both Chrome and Brave.
    4. Yes this can be reproduced. Happens every time. Tried uninstalling Chrome and reinstalling it.
    5. Expected result is to get the latest version of Chromium, Version 143.0.7499.169
    6. Uploading screen shot of error message.
This may be related to missing services.
If you go to Start, services.msc, do you see these three, and configured for their startup type correctly as seen here?
If it’s either not set to the right Startup Type, or missing in any way, the Brave updater cannot function and will cause errors such as these.
If that is the case, I may need to tag a developer here, since there’s an issue not quite Brave related, but Chromium related (as it isn’t just Brave with this error and issue, Edge, and Chrome can be affected as well, just never at the same time). IF those services are present, then this is something else.
I saw it in my services and their startup type is set ecatly as your image given but i wont still update
Ok thank you for checking. I wonder then if the updater itself is missing.
It should be located here:
If it’s present then I’m not entirely sure on this one.
the updater isnt missing
