Rubogen
February 15, 2023, 6:25pm
21
The problem persisted. I apologize that the video is a bit laggy, without the video everything works fine. You can see the problem on the video.
And this is with Hardware Acceleration
re-enabled?
Rubogen
February 15, 2023, 6:55pm
23
This is with hardware acceleration running, but Iāve tried with it disabled and the situation doesnāt change. Thatās why I didnāt record the video, itās the same, only the animation is even more laggy. With hardware acceleration on, the animation is noticeably smoother.
@Rubogen ,
Thank you for the information.
Iāve opened the following issue for the developers to review:
opened 06:56PM - 15 Feb 23 UTC
webcompat
OS/Desktop
<!-- Have you searched for similar issues? Before submitting this issue, please ⦠check the open issues and add a note before logging a new issue.
PLEASE USE THE TEMPLATE BELOW TO PROVIDE INFORMATION ABOUT THE ISSUE.
INSUFFICIENT INFO WILL GET THE ISSUE CLOSED. IT WILL ONLY BE REOPENED AFTER SUFFICIENT INFO IS PROVIDED-->
## Description
The site http://ventusky.com/ is a meteorological website that focuses on weather prediction and meteorological data visualisation. Brave struggles to fully load/display the map properly under most settings, although it will intermittently work properly in Brave. Note that this does work in Chrome and other Chromium based browsers.
## Steps to Reproduce
1. Visit https://www.ventusky.com/
2. Experiment with settings on the left-hand side
3. Observe Brave struggle to load/display weather map properly
## Reproduces how often:
Easily/intermittently
## Brave version (brave://version info)
v1.48.164
## Version/Channel Information:
- Can you reproduce this issue with the current release? Y
- Can you reproduce this issue with the beta channel? Y
- Can you reproduce this issue with the nightly channel? Y
## Other Additional Information:
- Does the issue resolve itself when disabling Brave Shields? N
- Does the issue resolve itself when disabling Brave Rewards? NA
- Is the issue reproducible on the latest version of Chrome? N
## Miscellaneous Information:
Original user thread:
https://community.brave.app/t/problems-with-animation-on-the-site/469039/22
cc @ryanbr
Rubogen
February 15, 2023, 6:59pm
25
Thanks for your help and interest in my problem:) I hope in future updates it will be fixed:)
Rubogen
February 23, 2023, 10:36pm
26
Hello, it seems that after the last update to Brave 1.48.171, my problem was fixed and everything started to load:)
system
Closed
March 25, 2023, 10:37pm
27
