Problème récompense juin 2023
Bonjour,
la récompense du mois de juin 2023 n’a pas été distribuer sur mon wallet
est ce normal ?
Cordialement
So you wanna say you did not receive the amount for the ads seen in May or ads seen in June ?
I did not receive the reward of the month of June
Okay got it. Best thing to do is to raise a ticket at
Then share the ticket id you receive in the email you submit
