@huub when you created your topic it had a template with information that is necessary. Any particular reason you chose to delete it and provide no details? Please reply back with the following:
So this is why the very detailed information is needed. When I briefly test and can’t experience the problem, it’s up to you to figure out what’s different.
I am going to guess it’s an extension you’re using or one of your Shields settings. It’s going to be up to you to experiment. Look at content filters enabled, if you need to change from Aggressively block trackers and ads to just Block trackers and ads, or what?
Issue was present with default and i tried with all shield and no shield
Brave 1.81.136 (Build officiel) (64 bits)
i’m on Windows10
Brave was new for me : loaded 2 days ago
and yes it happens in private window too.
for comparaison, Chrome and Edge have no issue.
I have no additionnal apps for now
I had played with content (change shields, block tracker, http(s) settings but as newbie) it seems that something in general version is blocking but i don’t know what. And asked help.
