Problem with 'Pinch to Zoom'
Hello,
I have issues with the “pinch to zoom” (on windows laptop)
When I zoomed before it was very progressive and fluid
Since today it zooms in and out by steps (110% then 125% etc)
It’s really annoying because I’m used to zooming in and out on the pages to read articles.
It happened somehow by itself, I didn’t touch the settings at all.,
Do you know how I can make it as it used to on my browser?
I tested on google chrome as well and it works just fine, I only have this issue with brave.
I am on the latest version of Brave (Version 1.46.144)
Thanks
Hello @meghdokania, thank you for reaching us out. Have you tried deleting your cache and cookies recently? Does the same happen in a private or incognito window?
In case it does not work can you try disabling Hardware Acceleration You’ll find this in Settings --> Additional Settings --> System --> Hardware Acceleration Hope it helps.
Regards.
