Problem with my wallet - sync problems
I’m using 3 installations of brave in 3 different computers (1 windows 7x64, and 2 macOS [high sierra and the other on Catalina]). Both on windows 7 and macOS high sierra i’ve got my wallet sync but I can’t sync on the Catalina one. I’ve restored on the last one but it keeps me asking to sync my wallet.
on the rewords Settings I can see this message Wallet restored! 0 BAT was recovered. Your wallet key has been verified and loaded successfully.
and yet it was supposed to get the amount of BAT’s that i have on the others 2.
Can some one clear me out with this?
I appreciated
Thank you
@EmperiuM,
By wallet sync, do you mean wallet verification?
yes, sorry. wallet verification.
@EmperiuM,
So what happens when you (on your Android device), launch the browser, open the Rewards panel, and tap Verify Wallet?
i don’t own any android device :wink: it’s macbook air :wink:
when I verify wallet I get this pop-up
and when I click verify it takes me to my uphold account
@EmperiuM,
Apologies – not sure why I said “Android device” :slight_smile:
Yes, you should be taken to your uphold account, aftrerwhich you should be notified that your wallet is verified and the Verify wallet option should now read:
yes, but that doesn’t happen in my browser as you can see below
do you need my brave://rewards-internals/ or brave://version/ to see anything?
@EmperiuM,
Thank you – I don’t think we need your internals information at this time. It appears that we have a fix for this issue waiting to be applied asap:
@Mattches ok, Thank you. I’ll wait for the fix.
Good work.
