**Description of the issue:**I have used Chrome for many years. I would love to switch my default browser to Brave except for one problem. The Google Calendar gadget does not work on Brave. It does work using Chrome and Microsoft Edge. I really refer to that gadget a lot and without it I am reluctant to switch to Brave.
Exact URL of the website in question: ighome.com
Did the issue present with default Shields settings? (yes/no) Yes
Does the site function as expected when Shields are turned off? No
Is there a specific Shields configuration that causes the site to break? If so, tell us that configuration. (yes/no): No
Does the site work as expected when using Chrome? Yes
Brave version (check About Brave): [Version 1.3.115 Chromium: 80.0.3987.87 (Official Build) (64-bit)]
