Problem with claiming bat ads in browser
App is updated, this is when you click claim. anyone having same issue?
Yes, I had the same issue but it was resolved automatically in around 24-36 hours.
still having same issue
What was the SafetyNet Test result?
I have the same problem. Could you solve it?
failed, cts profile matched
If your device fails the SafetyNet check, you won’t be able to receive rewards. You will have to correct whatever is causing it to fail.
