Problem metamask
I import my metamask account to another device (account created in brave 24 words) and it adds accounts that do not correspond, but I import it to brave and everything is fine, I don’t know what to do.
Hi @nachoruiz, can you confirm, is your issue with MM or with your Brave Creators account?
The problem is with my metamask account created in brave, I don’t know if that’s what you mean
You posted your comment in the wrong area.
Where should I post it?
You could try posting to https://community.brave.app/c/brave-rewards/rewards-support/73 At lease you wouldn’t be under the Creator section. I would also recommend you direct your post to someone at brave that might be able to help you like Mattches with Browser Support
Edit your original post and change the category to the one appropriate for this topic.
