Problem Login Uphold-Brave
This problem appeared to me, when logging into my uphold account. What can I do?
Error: Brave Rewards profile has been flagged
Unfortunately, your Brave Rewards profile has been flagged and you are unable to verify with a custodian at this time. This flag could be due to illegal activity on Brave Ads, but it could also be a false positive.
Important: While your Brave Rewards profile is flagged, you will not be able to verify.
No action from you is required. Your Brave Rewards profile will be automatically re-evaluated on a regular basis to determine when (or if) the flag can be removed. Try again from time to time to see if the flag has been removed.
Learn more about Brave’s process for flagging Rewards profiles
You need to raise a ticket at
Raising a ticket basically will be an appeal to Brave to reinstate your account and will be at Brave’s discretion to decide whether to reinstate your account or not.
Share the ticket id so if a team member sees this post it might expedite the process
